RCU Forums - View Single Post - Four Star ARF
Old 06-07-2005 | 09:35 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Four Star ARF
Thanks for the compliment about the SSE. Using Windex is a method for laying down monokote over monokote without using heat. RCU member did an thread about doing the windex method that is the best I've seen to explain how to do it. Luckily, it is the same thread that explains how to do the flag scheme too. It looks a little overwhelming at first, but it's really pretty easy to do. Check it out at
[link]http://www.rcuniverse.com/forum/m_603331/anchors_603331/mpage_1/key_flag/anchor/tm.htm#603331[/link]
Using windex only works on monokote, it won't work for ultracote. But if you want to do a covering job without bubbles in it you can't beat using windex. It's also nice because it give you a time to make sure your work it in place. The one down side is that it's going to take overnight for the pieces to dry out and be set in place. But in my mind that is a small price to pay.
Hope this helps
Ken
