RCU Forums - View Single Post - Using the ignition battery as ballast weight.
Old 06-08-2005 | 07:21 AM
WRK
Default RE: Using the ignition battery as ballast weight.
Try it, see if you get a good ground range check, if so it will work, I know of some installationns done this way for the same reason and it works fine.
