Just a quick comment. The Four Star line uses ultracote so using the windex method won't work without a little heat. I have the RED 4*60 and added 1 bay wide Yellow stripes to the wing bottom and a long yellow stripe from nose to tail. Some other stripes were also added to make it easier to determine the orientation. I used the windex method to place the stripes, then used a squeegee to take out all of the bubbles, then applied a little heat with a covering iron. This was my first time using the windex method with covering. If it did it over again, I would choose to use trim sheets that already have the adhesive on them. I will attach a picture of my 4* with the striping on the wing after I get home this afternoon from work.
