RCU Forums - View Single Post - Saving Trim Settings on FF9
Old 06-08-2005 | 02:18 PM
Bax
Default RE: Saving Trim Settings on FF9
Ideally, you use mechanical adjustments to put the control surface as close as possible to the trimmed position when the main trims are centered, and only then use the subtrims to take out any amount smaller than the mechanical adjusment can do. This keeps you from having large amounts of subtrim.
