Glue for epp foam?
I use both! Goop and Pro-bond, depending on the situation. Probond can save you some weight over goop if you spray it with some water first. By expanding, you don't need as much, thus you use less of it. But like Montague said, goop stays flexible, which is nice, whereas Probond hardens.
