Go Back  RCU Forums > RC Airplanes > RC Combat
Glue for epp foam? >
Glue for epp foam?
RC Combat Discuss rc combat planes, techniques and strategies here.
Glue for epp foam?
Old 10-08-2002 | 04:49 PM
Default Glue for epp foam?
What's the best glue to use on epp foam. I need something good to glue it to wood. I also need to know what is best for sticking the RSN to the epp foam.
Old 10-08-2002 | 05:15 PM
epoxy or poly glue works good for me for sticking foam to anything, don't mess with rsn too much, so I'd only guess foam safe CA or water-based polyurathane mixed with elmers glue.
Old 10-08-2002 | 05:40 PM
Really, epoxy works well on EPP foam too? Thanks, I didn't think it would.
Old 10-10-2002 | 06:18 PM
The best glue for EPP is Goop. It sticks like crazy and stays flexible, allowing the foam to continue to bend with out breaking the glue joint.
I haven't done ripstop with EPP yet, but the folks I know who have do it the same as with EPS.
Old 10-10-2002 | 07:07 PM
I thought Goop ate foam!
Old 10-11-2002 | 12:57 PM
Goop works great on EPP, but ONLY on EPP. It will eat any other kind of foam. BUT, I don't think anything will stick to goop if it is smeared on the outer surfaces to be covered. Use it carefully and don't let it get on the surfaces to be covered.
Old 10-11-2002 | 06:25 PM
Thanks for all the help folks!
Old 11-20-2002 | 02:38 AM
Default Great Glue
I've had tremendous success with Elmers PROBOND. Just follow the directions.
Old 11-20-2002 | 06:28 AM
Ditto on the Probond Polyurethane.
3M77 spray works pretty good too.
Old 11-20-2002 | 05:17 PM
Matt Kirsch's Avatar
My Feedback: (21)
You can even use CA on EPP foam.
For the ripstop nylon, water-based polyurethane mixed with white glue works best. Coat the EPP foam, smooth out the RSN, then run another coat of glue/WBP over that. Finally, top coat with clear WBP.
Old 04-14-2003 | 09:20 PM
the best glue we found for epp to wood is a glue called WELBOND. We use it to glue our cap strips onto the foam ribs.
Old 04-15-2003 | 06:13 PM
My Feedback: (8)
I use both! Goop and Pro-bond, depending on the situation. Probond can save you some weight over goop if you spray it with some water first. By expanding, you don't need as much, thus you use less of it. But like Montague said, goop stays flexible, which is nice, whereas Probond hardens.
