RCU Forums - View Single Post - JETCAT single channel ops,
Old 06-10-2005 | 11:39 AM
clguru's Avatar
clguru
Default JETCAT single channel ops,
Is there any problems related to running the Jetcat P120 with a single channel as opposed to using the AUX channel setup?
Are there any things I must know before do teach to my radio? When I read about teach RC in the manual it says to place AUX channel in run or shutdown position etc., but if you aren't running the AUX channel how do you set it up?
The reason I'm trying to do this, is because I'm using a Futaba 9C radio and I'm running out of channels. Rudder, elevator,aileron,flaps,throttle,speed brake,retracts,brakes. I'm using two channels for stabs, so I need to free up another channel.
Setting up the failsafe is going to be fun too, but thats another post I guess.
Would it it be simpler to just buy a JR 10X and set it up the normal way?
Thanks Dan
