ORIGINAL: jfarthing
Bill,
I mounted my engine (G26) yesterday and found that the prop nut adapter included with the stock GP spinner would not fit. Can you tell me what size prop nut adapter will work and where I could order one?
Thanks again for all your help
John
Go to the tru-turn web site and act like you are going to buy a the same spinner. Once you choose the spinner then you get the option to pick a prop nut adapter...
http://www.tru-turn.com/
Once you get the size you can go to towers web site and get it much cheaper.
I honestly cannot tell you the size you need. The RCIgnition converted G26's have a prop bolt drilled for a 10-32 bolt so I did not need an adapter.
Also I just remembered. If you got to Horizon Hobbies web site and look under Zenoah, You will see the G26 listed there and I am pretty sure under optional accessories it lists the prop adapter and size required
