RE: Honey beeCP2 problems
On the honey bee cp2 make sure the 3d switch that is the one in the top left is clicked away from you and the throttle and throttle trim are set to the lowest positions or it will not initialize if this does not fix it you most likely need new crystals. Also check and see if the throttle servo reverser is set to the norm position and not reversed.This is located in the lower right corner of your transmitter. Once you get it running hopefully just the 3d switch prepare yourself for an excellent experience with your honey bee i have two and there the nicest micro helicopter i have flown and don't worry to much about crashing i smashed into the ground very hard yesterday trying to perform stunts i know i cant do yet
the only thing that happen was i lost the little piece of fuel tubing off the tail shaft make sure you get some extra pieces of this other than that i picked it up unfolded the blades an took of again.Also contrary to popular belief this helicopter handles the wind quite well, giving you can fly without wind so good luck.
