Go Back  RCU Forums > RC Helicopters > Electric RC Helis
 Honey beeCP2 problems >
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Old 06-11-2005 | 06:39 AM
Default Honey beeCP2 problems
Hi all
just recieved my honeybee CP2 from ebay. All ready to go switch on tx then plug in reciever to li poly battery..a short kick from the servos then nothing []. The controller refuses to initialise ie. it flashes red and green . Any ideas or is the controller just faulty?
Has anyone else had the same problem?
Thanks in advance
Old 06-11-2005 | 07:19 AM
Default RE: Honey beeCP2 problems
On the honey bee cp2 make sure the 3d switch that is the one in the top left is clicked away from you and the throttle and throttle trim are set to the lowest positions or it will not initialize if this does not fix it you most likely need new crystals. Also check and see if the throttle servo reverser is set to the norm position and not reversed.This is located in the lower right corner of your transmitter. Once you get it running hopefully just the 3d switch prepare yourself for an excellent experience with your honey bee i have two and there the nicest micro helicopter i have flown and don't worry to much about crashing i smashed into the ground very hard yesterday trying to perform stunts i know i cant do yet
the only thing that happen was i lost the little piece of fuel tubing off the tail shaft make sure you get some extra pieces of this other than that i picked it up unfolded the blades an took of again.Also contrary to popular belief this helicopter handles the wind quite well, giving you can fly without wind so good luck.
Old 06-12-2005 | 05:05 AM
Thanks Blaylock
Unfortunately idle up is off and throttle and throttle trim are zero..tried another pair of crystals from my other radio...looks like the 4 in 1 unit is faulty[]. Got this new off ebay so hopefully my seller will do the honorable thing and send out a new 4in1 unit.
