3. Forgot to make larger holes in the ribs for the servo cable to go through. Gonna have to find a good way to enlarge them now.
To me the holes in the ribs look big enough, unless they are smaller than the cable diameter. I don't understand why people always drill huge holes and install wire tunnel tubes. I just put in the cable (with some extra inches) in before covering (or sheeting), then solder servo and plugs to it after covering. If I have to replace the servo I cut and solder. Did you ever have to replace a servo cable?
