RE: help needed with diffs
You can just spray them but i find the best way (and cost effective) is to spray it into a container. You end up with about 1" of liquid WD40 that you can just drop stuff into. Really gets the crud out. When you finished, seal the container and use it again later. You can easily clean out 3 diffs with it.
It will look crappy after 3 diffs but dont worry, still works fine.
