RE: X-Cellerator
I got one and I can tell you that the car is very good, but the radio system(Hi-tech) is not that good, I have to replace my with an Airtronics one and it work perfect. The turnbuckle snap a lot, so I replaced with Traxxas sistem one and it works great. Make sure if you get one to put threadlock in the pull star screws and also in the main gear, the hex screw from the flywheel come loose. Good luck
