RCU Forums - View Single Post - Homelite 25cc conversion and pics...
Old 06-12-2005 | 06:50 PM
hockeydust18
Default Homelite 25cc conversion and pics...
Hello,
I just bought a Homelite weed wacker the other day and took it apart,cleaned it, and put it back together in just under an hour...The only mods i made for now were to re-size the back plate and hack-saw the fins off the fly wheel.I bolted on a nose cone so i could use my starter,put it on pressed the button started in about 3 seconds...so i still need to cut away the front plate some how which is part of the crank case,any ideas on which tool to use for this job?ive got a hack saw and dremel..so i need to know which parts to order and if wacker engines has them for the 25cc homelite...i will be trying out a 16x8 wooden prop first so i need their prop hub,im gunna get the machined fly-wheel also,the exhaust,and back mounting plate...anything else?i would rather wait on the carb for now as im trying to keep spending down...i plan to put this on a lanier stinger 1.20...any feed would be great..there's some pics below...thanks for help..dustin
ID:	283891   Click image for larger version
ID:	283892   Click image for larger version
