120mm
but they are not i direct fit!
Mine are cut down to 110mm and some of the material around the strut has been removed so it can retract 90 degrees fully with the springair unit. They are also drill up from 4mm to 5mm for the connecting 5mm pin.
So you cant call them a direct drop in fit
