RCU Forums - View Single Post - INVERTED AND FALLING?
Old 06-17-2005 | 12:25 PM
MHester's Avatar
MHester
Default RE: INVERTED AND FALLING?
Wing incidence, balance and thrust all play a factor in this. Start by double checking your CG (You do NOT want to get a Kougar tail heavy!) and then check your wing incidence. Make sure you don't have a ridiculous amount of positive. Lastly if you've checked everything else, do a thrust line check.
A Kougar needs a good bit of down elevator inverted, but not an excessive amount. It doesn't like to slow down though.
Have fun,
-Mike
