Need help clearing a prob............
Hello all, I have a question pertaining to tail-lock gyros. I was told by someone that you DO NOT trim the rudder with the main trim on the TX to get the heli "trimmed" out, instead, you make mechanical adjustments to get it right and use the sub-trims to correct it if its "pulling" to the right or left. Also, by using the sub-trim, wouldn't you have to re-adjust the tail rotor linkage at the blades? To get the proper pitch?? So help me out guys.............I'm frazzled..........
Nitrobuzzard
