To Program, or Not to Program ????
Our advice is to reset the older pre-Oct. 2001 servos to the default with the reset function in the programmer.
You should not have to "program" them unless you wish to change any of the default values.
The reason for the twisted wires on the newer digital servo product is to potentially help reduce glitching caused by longer servo leads in aircraft applications.
