RCU Forums - View Single Post - Homelite 45cc Carb
Old 06-20-2005 | 12:20 AM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Homelite 45cc Carb
The dimensions are venturi sizes, not the throttle bore size.
The Homelite 45 uses a ZAMA C1Q-H44 =14mm =.551" venturi. Zama's have no number cast in venturi inlet
The throttle bore size for theZAMA is 16mm = .630" or a little over 5/8"
The G 38 uses a Walbro WT-338 =13.49mm =.531"= #34 cast in inlet Throttle bore is 17.44mm or 11/16"
The G 45 uses a Walbro HDA48D =15.08mm =.5937"= #38 cast in inlet Throttle bore is 19mm or 3/4"
Enjoy,
Jim
