RE: Pull Pull on Funtana 90 Anyone?
Well there are several different ways to do the pull pull, after I got mine put in I kind of wished I had done it a bit differently so check through the thread and find one that works for you. If you decide to do it, finding suitable cable exits to cover the holes is a tough one, or you can just leave slots, or I used Ny-Tube all the way down the fuselage and covered the exit with Ultracote. That could have turned out better, but I got in too big a hurry about that time of night...
I put the Sullivan 10-15 lb version tailwheel on mine, the LHS showed the way they did there's which is to use four small cap head lag screws. You'll need to enlarge the holes in the bracket just a touch, mark and drill them on the fuselage. Then run the cap screws down in, back them out, fill with some instant CA and install the bracket. It works slick.
Zeeb
