RE: Super Tiger 40-Ringed
There's only one way to properly set a ST low end needle. Put a short piece of fuel tubing on the carb nipple. Close the throttle to idle. Blow into the tubing while slowly opening the idle needle. Hole the engnie to your ear. When you can just hear air blowing through, you'll be within 1/4 either way of the proper setting.
Dr.1
