RE: CA 27% extra
thanks for the reply, so now i got to get the horns down first before covering and check for clearance for elevator and rudder. will the tap method through the dowls come loose? glue maybe help? ok, this is a tail dragger so what tail asemble do you MOST recommend? this is a big plane so i don't think i can use the JUST wire method, maybe spring? i'm running out of questions here, but ANY other MODS or SUGGESTIONS, will surely help me because this is my first. oh yeah.. how do i line up the control horn and servo horn to get the maxium throw? as for the elevators halves don't i need to reverse one servo, and wouldn't that changes everything?
PS. please tell me what i should buy first... servos or engine... i'm still toggling between the two. pros and cons?
