RCU Forums - View Single Post - AMD Hawk.
Thread: AMD Hawk.
Old 06-23-2005 | 10:30 AM
  #395
john agnew
Default RE: AMD Hawk.
Guys
The Hawk is ready to go. Ran tests today including turbine run / range check all o.k. Final weight 10lbs 4oz dry CG 140mm back from LE dry 130mm back with full tank. All throws as per Wren turbines model including crow braking on ailerons (4mm up at full flap) elevator is mixed with flap to give 5mm up at full flap (45o) Test flight will be on Saturday.
John
ID:	288706   Click image for larger version
ID:	288707   Click image for larger version
