RE: SIM Compatible?
I wasnt talking about the CP2 transmitter. Im talking about the one that comes with the Blade. Its an exact duplicate of the standard e-sky transmitter, the one that comes with the honeybee and the carbooon, and the hundred other varients they have...CP2 excluded.
I still cant see why you would need the "CP2" transmitter anyway. A LCD voltage display vs the old style LED display. Whooopty dooo. A freq module? All you had to do with the old style was pop the crystal out and stick another one in....and a trainer switch. WOW, another completly useless item for a helicopter, which is also on the older versions.
If they wanted to upgrade the thing, how about putting user adjustable exponentials on it, and maybe an adjustment for throttle/pitch curves. Then I might actually consider upgrading my Tx. Ive got both the standard E-sky Tx and the E-flite Tx. They are both interchangeable. The only difference is you can switch the Esky one to mode 1 or mode 2, where as the E-flite one you cannot, and the stickers on the front are different.
