BME 100 Prop & Spinner
Need a prop & spinner for a BME 100.
The engine was previously run (just purchased used) on a 26/10.
I assume I would run a similar prop on my older (just rebuilt it - from a different modeler from the above listed one) Carden 35% Extra (should weigh 26 - 27 Lbs when done).
There is some used stuff I have seen that is drilled for 3W/DA- would I be able to use one of these by enlarging the single hole to ~7/16 or will there be too much weakening already?
What alternative size/pitch props would be acceptable?
Let me know your thoughts and what you might have available to sell (or Trade)
Eric
