BME 100 Prop & Spinner
My Feedback: (14)
TX
Need a prop & spinner for a BME 100.
The engine was previously run (just purchased used) on a 26/10.
I assume I would run a similar prop on my older (just rebuilt it - from a different modeler from the above listed one) Carden 35% Extra (should weigh 26 - 27 Lbs when done).
There is some used stuff I have seen that is drilled for 3W/DA- would I be able to use one of these by enlarging the single hole to ~7/16 or will there be too much weakening already?
What alternative size/pitch props would be acceptable?
Let me know your thoughts and what you might have available to sell (or Trade)
Eric
Eric
You can use a prop that has been drilled for the 3W/DA/zdz. I have used them on my BME engines before. Just enlarge the center hole like you mentioned. The 2 props that I prefer on my BME 100 are the Menz 26-10 and the Airwild NX 26-10. The BME engines are easy to use and powerful, so you will like it. As far as the spinner goes, just pick a size that fits your cowl.
My Feedback: (16)
GA
I have tried a couple of pre-drilled props.
I always fill in the holes with epoxy and then re-drill them for the locatior studs.
People say this is wrong, but works for me.
My Feedback: (14)
TX
Thanks for the replies.
I bought a prop & spinner already drilled for a 3W/DA.
Now some solid advice regarding filling the 3W/DA holes in the prop that are now not needed.
Will filling these holes be beneficial?
Is the hole filling with epoxy only appropriate for composite props only.
The prop I bought is a Menz wood. Which makes the most sense
1) leave the holes - do nothing
2) Fill the holes with epoxy
3) Epoxy in dowels to fill the holes
Thanks for the guidance
Eric
Eric
I have thought about this as well - though in my case I am contemplating filling in holes to re-drill a new 6 bolt pattern.
If you use epoxy I suppose you could consider mixing in heavy dose of milled fiberglass- anybody tried that?
Dave Michael
Dave Michael
