RCU Forums - View Single Post - need tuning help!!!
Thread
need tuning help!!!
06-23-2005 | 10:09 PM
3
beanutputter
Dec 2004
14
Mcdonough, GA
RE: need tuning help!!!
Thanks for your quick response and good ideas. The fuel does flow unrestricted when disconnected and even pours threw the carb depending on where the tank is mounted. I did check the filter screen in the walbro and found it clean. At the same time I checked the diaphragm and it looked good. As far as air leaks, I don’t think this is the problem, I have remounted the carb many times and I have a good gasket. I think you are on the right track with fuel delivery, I am not too clear on weather or not my tank is set up properly. I am including some pics, do you see anything wrong.
Reply
Like
beanutputter
View Public Profile
Send a private message to beanutputter
Find More Posts by beanutputter
View iTrader Profile
