RCU Forums - View Single Post - Goldberg Anniversary Cub as a Trainer?
Old 06-24-2005 | 07:08 PM
FFSmitty
Default RE: Goldberg Anniversary Cub as a Trainer?
Got the engine to run for about 3 seconds or so and it cut off. I turned it over several times without the glow plug attached and it still wouldn't start. It acted as if it had lost compression until I turned it over three to five times. Then it would want to kick back. Maybe the needle valve it not set properly. I had the choke open a little when it first started, and then closed it, no luck, opened it back up, no luck, then all the way open, no luck. Turned it over again several times to clean out the engine but still would start. Any suggestions?
FF Smitty
