RCU Forums - View Single Post - CA models 27% extra question
Old 06-25-2005 | 05:30 PM
v-snap's Avatar
v-snap
My Feedback: (18)
Default RE: CA models 27% extra question
Drill jig helps locate the bolts to mount the prop. Unless you can find a prop manufacturer that pre-drills the props you will need for the best results.
CA = Columbo Anderson or Composite ARF?
Ignitions battery and switch, think about a smartfly with engine kill for this..
Muffler, cannister, or pipe (header for latter two) this also goes back to CA question as a pipe or cannister won't fit in the fuse of the Columbo Anderson kit
