CA models 27% extra question
hi guys!!
im thinking on getting a 27% CA models extra and i have some questions since this is going to be my first gas powered large aircraft, so i hope you guys can help.
im thinking to put a DA 50 on it.¿what do need to complete the engine? ¿what is a drill jig and what do i need one for?, is there anything else that i will need to complete the engine? i allready have a showtime smoke sistem ¿do i need a smoke muffler? i cant think of anny more questions rightnow so please feel free to do anny coments on your aircraft configuration
i really apreciate youre help
thanks very much
thanks very much
My Feedback: (18)
IN
Drill jig helps locate the bolts to mount the prop. Unless you can find a prop manufacturer that pre-drills the props you will need for the best results.
CA = Columbo Anderson or Composite ARF?
Ignitions battery and switch, think about a smartfly with engine kill for this..
Muffler, cannister, or pipe (header for latter two) this also goes back to CA question as a pipe or cannister won't fit in the fuse of the Columbo Anderson kit
