Rafale vs Hotspot setup
I have been following the Hotspot info as to the proper setup on the elevator function. 15mm and 3/8 " up from neutral , has been mentioned.
My question is, should the elevator function on he Avonds Rafale be set to a positive angle from neutral and if so, how much ?
I have been flying the Rafale throughout the summer and it does take a long takeoff run to get it off the deck. (4500ft altitude). Would it help to set the Rafale up simular to the Hotspot?
Rod Springer
