ORIGINAL: exeter_acres
sorry your search function isn't working.....
Warning - you can easily find a lot of posts with exactly the same topic. unless you give us some background that is different from others, you can just refer to them. if your first plane was a 50% edge, those planes you mentioned seem a little small. on the other hand, if your first plane was a piece of folded newspaper or a foamie from kmart, you might consider a trainer.
