RE: What next?
If you want a true 3D bird, look at the Hype 3D or a Flip 3D. Longer tail moment, thicker airfoil with BIG control surfaces. If you could find a Madness or a Laser 3D (kit) those are both great.
For pure 3D performance avoid a scale bird unless you go big.
OMP has a bird on the way called a Fusion that should be a 3D wizard. Thin fuse, however not a true profile, long tail moment, big control surfaces, however with a pattern type wing. Looks like a wonderful combo. Saw it at Toledo and Joe Nall, tried to by one both times, however they only had protos and wouldn't sell either the 40 size or the 90 size.
