You are correct. If you want you can put something under the muffler to catch it. Or disconnect the vent from the muffler and put an overflow bottle to catch it. Either way it will go through the vent and will not flood your engine.
ORIGINAL: jbrundt
Thanks guys.
I guess when you fuel it's not a big worry for fuel to travel up the carb feed line, right? Any overflow should go out the vent line.
Jeff
