RCU Forums - View Single Post - Saito 100 in U Can Do and extended hovering
Old 06-29-2005 | 11:43 PM
WRK
Default Saito 100 in U Can Do and extended hovering
Have a Saito 100 in U Can Do, it flies great but when I do hovering for more
than 30 to 45 seconds I lose engine power to the point that I have to stop
hovering or I won't have enough power to pull out anymore. I think the
engine is getting too warm, I have richened the high speed needle and will
open the cowl more although it is fairly open, just wondering if this is a
normal problem?
I am using exhaust pressure and a 15 X 4 prop. and 15% nitro fuel, the plane
will climb out of sight if the throttle is open I only lose power in hover after a short while
but I would like to be able to hover for a longer period of time.
Has anyone else run into this problem?
flierbk
