RE: Convert WT-324 to WT-499
You need to replace the inlet needle and the diaphragms. red tipped viton inlet needle and brown colored fiberglass diaphragms.
Methanol requires an A/F ratio of 6.4:1 or 2.25 times more than gas.
The internal passages may be larger on the alky carb.
