RCU Forums - View Single Post - Showtime 4D 2C Engine installation
Old 06-30-2005 | 03:57 PM
Doug Cronkhite
My Feedback: (34)
Default RE: Showtime 4D 2C Engine installation
ORIGINAL: bbrundle
Mike I am planning on using the Evolution 100 in my Showtime 4D. Which pitts muffler would you recommend? Would you run a pull/pull set up or mount the rudder servo in the tail?
Thanks in advance
Bill,
If you're using the Evolution 100, I'd suggest putting an 8411SA in the tail for rudder. The Evolution weighs a little over 28 ounces with muffler to the Saito 100's 21 ounces. Using a Pitt's muffler will likely be an ounce or two more than the stock.. so the rudder servo in back makes sense.
