RCU Forums - View Single Post - Saito 100 in U Can Do and extended hovering
Old 06-30-2005 | 04:27 PM
rightflyer
Default RE: Saito 100 in U Can Do and extended hovering
You could try running it without a cowl to see if the problem disappears. It would at least tell you it was heat-related. Can't see your cowl, but the exit opening must be at leat 2x the size of the input. Most people overdo the intake opening. I knew a guy that just put his engine upright and put it thru the cowl-no heat problems there!
