RCU Forums - View Single Post - Sukhoi First Flight...
Old 10-15-2002 | 01:43 AM
daven
Default Sukhoi First Flight...
8u stepped trim.
Stepping the trim tabs down to 1 is a good idea, but only do it AFTER you have the plane basically trimmed out.
If you are test flying a new plane on Step 1 and its way out of trim, it takes a lot of pushes to get it right. Leave it at 4 until you have it initially trimmed, then you can knock it down to 1 and fine trim it.
I was not thrilled at first with the digital trims, but have learned to really like them. You will get use to them, and I would bet, will actually prefer them after you get use to them.
Set up a Throttle kill switch, so you don't have to use the throttle trim to shut down the engine.
I hope to get the 60 sized yellow Sukoi this winter..
