Originally posted by dhable
I've been flying RC for 9 years, and have used Great Planes EZ connectors on every servo of every airplane I have built. I have never had a failure.
I fly .60-sized airplanes, Top Flite fighters for the most part.
I use them because they are the easiest to adjust. I tighten the bejeebies out of them, and check them before each flight and have yet to experience any ez-connector related failure. In fact, I've piled a few in (my fault) and the connectors held even after the jolt of a nose in crash.
Hi dhable, are you referring to the gp screw lock connector (made of brass with a screw for securing pushrod) or the fastlink (made of nylon and snaps into the pushrod) ? Dubro's ez connector is equivalent to the gp screw-lock connector.
