RCU Forums - View Single Post - Simple carb rotation plate
Old 07-03-2005 | 01:06 PM
av8tor1977's Avatar
av8tor1977
Default RE: Simple carb rotation plate
Nice work. However, it is so easy to tap the pump top on the carb for a fitting, and then tap the case somewhere convenient to run a tube for the pulse to the pump that I never mess with the original pulse port when I change things around. Also, the pulse hole is often in the way when I open my manifolds up for bigger carbs.
Thanks for the pics,
AV8TOR
