Sky Scooter
Want real fun with it? Get a endoplasma buggy motor. Cut the nose off about where it usualy breaks from gettign nosed in then make the motor hole bigger so it will fit in there. Get a MEC superbox ratio 6.0:1 and a 12X10 prop put it together and glue it in. You will need atlest a 30 amp esc. Next get a 10cell HR4/5FAUP pack and fit it into the fuse. You will need to cut the battery slot back some but not to much. Next take 1/16 bulsa and sheet the bottom of the wing. These mods will make that Sky Scooter go straight up outta sight if you want it to.
Pat
