Sky Scooter >
Sky Scooter
Sky Scooter
Old 10-13-2002 | 03:31 PM
Default Sky Scooter
I recently installed a 3:1 gearbox on my Sky Scooter which I purchased from Servo City. I am also using the 9X5 slow flyer prop. Does anyone know whether the folding prop recommended for the Hitec gearbox will fit the 3:1 ball bearing gearbox? Are the gearbox shafts the same diameter size?
Old 08-22-2003 | 02:05 AM
Default Sky Scooter
As far as I know (not much) the folding prop will not fit the ServoCity 3:1 gearbox because that comes with the fittings for an APC prop. I have not yet installed my gearbox because they sent me the 1.7:1 instead (which I am keeping for fun!!!). The real challenge will be getting the brass gear off of the motor shaft. I really do not know what I am doing but I love the Scooter!
Old 08-22-2003 | 02:55 AM
Default Sky Scooter
the pinion comes off fairly easily with a quick touch from a torch...
finally got my SS up again, what a blast to just fly!
Old 08-22-2003 | 03:01 AM
Default Sky Scooter
Thanks R. Kramer, but did you have to do anything to the engine black plastic mount?
JimH
Old 08-22-2003 | 01:45 PM
Default Sky Scooter
Want real fun with it? Get a endoplasma buggy motor. Cut the nose off about where it usualy breaks from gettign nosed in then make the motor hole bigger so it will fit in there. Get a MEC superbox ratio 6.0:1 and a 12X10 prop put it together and glue it in. You will need atlest a 30 amp esc. Next get a 10cell HR4/5FAUP pack and fit it into the fuse. You will need to cut the battery slot back some but not to much. Next take 1/16 bulsa and sheet the bottom of the wing. These mods will make that Sky Scooter go straight up outta sight if you want it to.
Pat
