RCU Forums - View Single Post - Twin Somethin' Extra
Old 07-05-2005 | 05:25 AM
rrudytoo's Avatar
rrudytoo
My Feedback: (27)
Default RE: Twin Somethin' Extra
DamonTX,
Congratulations on a fine job! Your "SD" came out looking like it was meant to be that way from the factory. I'll bet it's a hoot to fly!
I'm glad that you're going to continue to refine your efforts with another build and I have a suggestion. Move your engines inboard as much as you can. The further out, away from the fuselage centerline, they are the more adverse yaw will be induced should you lose an engine. This should be a relatively easy modification for one of your talents and it should improve your roll rate and roll recovery, too.
Good luck and keep those posts coming!
Al
