RCU Forums - View Single Post - Twin Somethin' Extra
Old 07-05-2005 | 08:31 AM
DamonTX
Default RE: Twin Somethin' Extra
Thanks guys! I got three more flights on it Sunday. Two weeks ago I was having trouble getting the engines synched but all is fine now. The flights the other day were great. I'm moving past the test flight stages and am now really starting to ring it out.
Al... I totally agree with you on moving the engines inboard a little more. Found this out on a dead stick a while back, whew! that was a close one! When I do the bigger one this winter, I'll probably make it so there's only about 1.5" of clearance between the tip of the prop and the fuse. For balance reasons, the tank will likely be in the fuse and the nacelles will be a little longer to help out with balance as well.
Now would someone else give this a try? I promise you'll have a blast.
Damon
