ORIGINAL: skyodyssey
jdmmax,
Forgive me for being thick headed, but I have one more question. I have seen a picture similar to yours and I was thinking the gas tank would be in the way, at least if it has the same dimensions as the Mach roto start.
Also, the Nova spins the same direction as the LST roto start? If not, I can use a drill and put it in reverse
uhmm it looks like there will be two gears in there if there are it will require you to spin the roto star opposite direction of the losi rotostart.
