RE: Spinner help...
using an old enya 120R 4 stroke that i've had for a while with an ali mount that i've used with this engine before, but even when i looked at using the stock mount or a different mount i had i have the same problem.
The engines carb is located at the back of the engine, so even once i've mounted the engine at the most rearward position on the mount the prob shaft pokes out of the cowl quite far...so when i put the back plate of the spinner on im left with this gap...bad times, never mind, guess i'll have to deal with it.
people who are using saito 120's, 150's and 180's must be having the same problem, unless this engine is just particularly long!
