IMO, neither! I admit strait away i have never flown either of them, but ive flown the Extreme Flight RC Yak 54 (68") and its THE bollocks! i cant stait how well this plane flys, lets let the vids talk:
this is my video:
http://www.3drc.info/media/flights/Yak_54.wmv
EFRC vid:
http://www.freestyle-rc.com/video/68_yak54.wmv
Some EFRC customer Vids:
http://www.extremeflightrc.com/produ...ust_vid_01.wmv
Impressive or what!?!?!
Best performing engine?
YS110 or Moki 135
Most reliable / easy to set up engine?
out of the two above, the Moki 135
Which is better for FAI?
This yak won the AMA masters pattern comp against dedicated 2M machines, obviously it needs to be trimmed well, but it will fly beautifuly smooth
Better for 3D?
look at the vids posted above, as you can see its amazing, vertially no wing rock and with the ultra low wing loading it floats, but with the thiner wing, it tracks very well
Best at being a compromise for both flying style?
This plane is designed as a freestle aerobat, in other words it perfroms both with ease
Lightest?
Mine weighs sub 9lbs (i think its 8 1/2 lbs), with a wing area of 920 square inches, its very light for its size
Better quality build?
Look at attached pics
Better quality covering?
All oracover, profilm in the UK, ironed on to a very high standard
More crash resistance?
Only 1 UC has been ripped out in the history of these planes, and the reason for that is the wheels rollind under the sandown "runway"... a bit like hitting a brick wall
. Ive "landed" very hard a few times, i wouldnt be suprised that many planes would quite easily snapped in two on some of them, but with mine, all i did was repair the actuall UC legs, and fly again!
More repairable?
Never really had to do it its so strong!
Avalible from [link=http://www.freestyle-rc.com]Freestyle-RC[/link] from a Guy called Daniel Roser. They cost £275. Thats more than the adrenalin, and possibly the synergy (im not sure), however! you get ALL dubro hardwere, including dubro 16oz tank, dubro closed loop, 4-40 rods, dubro everything basically! and to top it off it even comes with a carbon fibre wing tube as standard! strong enough to withstand full power dives strait into really fast tumbels. Also, for an extra £25 you can get a set of wingbags which fit like gloves.
The only slight problem is as yet they are not in stock, but trust me, its worth every minute of the wait!
Heres some pictures of it....
Ian
