RCU Forums - View Single Post - LST
Thread: LST
Old 07-07-2005 | 03:29 PM
2DMaxLST!!'s Avatar
2DMaxLST!!
Default RE: LST
ORIGINAL: REVOFAMILY
Shock rod ends & shaft(2) - $1
Spur Gear (2) - $6
Front A-arm set (2) 1 free replacement ... one $6 from online source
Rear A-arm set (1) - $6 from online source
Reverse gear (optidrive sensor gear) Just took it out... - $0
Bent a turnbuckle (bent it back) - $0
PRO-1 rocker arm - Switched to LT's.. Free mod - $0
Rear Differential - Replaced by Traxxas - $0
EZ-Start case (landed upside down from 10 ft. high on asphalt) - $10
Now, let's do the math... 1+6+6+6+10= $29 ... which is UNDER $30
Everything else was an upgrade... and did not need to be replaced, I just did it for fun... (2.5r was still running... and pretty well, I might add... even with the scored sleeve) Motor mount came with the new engine... P2's were an upgrade from the LT's... Wheels and tires and body are getting ready to be replaced after almost 3 gallons of use... and hard bashing to boot...
Well you know that most people would count the $$ for broken parts replaced by Traxxes and broken parts that you just removed, I mean come on. Anyone knows that a 2.5r tuned for anytype of performanc only last 2~3 gallons. I should know I have had three of them. Out of the three one of them actually ran pretty consistent.
