RCU Forums - View Single Post - Hinges
Thread: Hinges
Old 07-09-2005 | 09:16 PM
Fastsky's Avatar
Fastsky
Default RE: Hinges
Ca hinges will give you trouble if they are not installed correctly. You could go to the type of hinge that is made of 2 plastic pieces with a steel pin between the 2 halves. These use epoxy but make sure you go back and pin them in using round toothpicks and glue.[8D]
